SPEED BLEEDERS
Old Apr 19, 2008 | 09:49 PM
gtagg's Avatar
Default SPEED BLEEDERS
Welcome back Mike, O.K. guys, I am looking for speed bleeders, I found some different places to buy them. but. I need to know what size the bleeder thread size is, for a 2000 disco II. If I can find them cheap enough, they might be worth it. so far, 11.99 for 2 -14.99 for 2 are rear bleedersdifferent from the fronts? Has anyone used them?
Thanks Gents
gTAGG
Old Apr 20, 2008 | 09:50 AM
Default RE: SPEED BLEEDERS
What are speed bleeders??????????????????????
Are you wanting to bleed your brakes, if so the 4 calipers have the same size bleeder valves.
If it is for the brakes, why rush thru bleeding them, are you using a pressure bleeder? Still need to watch the fluid till you get all the old fluid out.
Old Apr 20, 2008 | 04:49 PM
gtagg's Avatar
Hello Mike, Speed bleeders, Are bleeder valves with a ball bearing inside of them. basically, it makes it a one man job. all you have to do is open the bleeder get in the car and pump out the old fluid. you dont have to close the bleeder valve every time you pump up the brakes. a spring and ballbearing inside of the bleeder valve allows the fluid and airout but will not allow anything back through the bleeder.I am told it makes things go much faster, when changing out old fluid. you know,I had a feeling you would be theone to get back to me. Did you post any pic's yet, from yourlastest adventure.
gTAGG
Old Apr 20, 2008 | 05:58 PM
jkid's Avatar
I use the cheap $3 bleeder that any parts store has (just got done using it actually) all the time. It's just a tube that can fit over the bleed screw (it has a plastic cone adapter that fits into it too) and a small bottle for the fluid to run into. I've never had a problem with it.
soupdogg
Sep 25, 2007 12:49 PM
Kiwi Mike
Mar 2, 2006 07:32 AM
garover
Apr 3, 2005 01:14 AM
sdunham44
Feb 13, 2005 11:42 AM
KENWOOD
Audio/Visual Electronics
Jul 11, 2004 12:10 PM
