Speedometer Cluster Illumination
Old Oct 9, 2021 | 12:17 PM
RizzleKicks's Avatar
Default Speedometer Cluster Illumination
Evening Folks ,
2003 D2
After spending the whole day driving , I went to park the Disco up for the night & realised the Speedometer Cluster had no lights and no lights around the heater switches total darkness. Now the Speedo was working but no light.
Can anyone shed any light on what may be the issue . I was told to check Fuse 13 under the bonnet & Fuses 11 & 33 and they did not seem blown.
RizzleKicks
Old Oct 9, 2021 | 02:05 PM
Harvlr's Avatar
Presumably you checked that the dash dimmer control isn’t turned to the dimmest setting?
Old Oct 9, 2021 | 02:07 PM
Harvlr's Avatar
I’m not trying to be a smart-@ss but sometimes we overlook the obvious.
Old Oct 9, 2021 | 03:30 PM
Does the D2 have a dimmer switch😱 and if so where is it located ? 🤔
Old Oct 9, 2021 | 05:07 PM
Harvlr's Avatar
I’m not with my D2 now but IIRC it’s left of the steering wheel (on a LHD), I think a black rotating disc
Old Oct 10, 2021 | 09:38 AM
The_OGCJR's Avatar
yes. Left of steering wheel. It’s a knurled plastic wheel
Old Oct 10, 2021 | 09:39 AM
The_OGCJR's Avatar
Forgot to mention. I’ve had this issue and I gently tapped my key forward and the lights came on. So it was a loose connection in the ignition switch
Old Oct 11, 2021 | 12:53 AM
Tried that with no luck either. Does this have a relay or a fuse in the engine compartment ? Just not enough information available
Old Oct 11, 2021 | 02:11 AM
Discorama's Avatar
Maybe all the bulbs are blown? The stock radio button lights are dimmed too, but it uses LEDs which last forever. Can you dim them?
apigo200x
Range Rover L322 (3rd Gen)
Jan 9, 2021 05:54 PM
abran
Jun 5, 2016 09:22 PM
treihammond12
Jul 27, 2015 06:45 AM
G Reeves
Oct 17, 2013 12:23 PM
pjvarc
Aug 5, 2011 04:23 PM
