Speedometer sensors
Old Mar 26, 2015 | 08:16 PM
Jnj's Avatar
Jnj
Default Speedometer sensors
What sensor or sensors are responsible for transmitting the signal to the speedometer? What is the path it takes? What is the failure points in the system?
Old Mar 26, 2015 | 11:40 PM
abran's Avatar
I believe it's the ABS sensors at the wheels. In the D1 there was a VSS at the t case.
Not sure about failure points besides sensors and BECM.
Old Mar 27, 2015 | 05:39 AM
dgi 07's Avatar
What seems to be your issue.?
Old Mar 27, 2015 | 06:38 AM
Jnj's Avatar
Jnj
My speedometer/odometer either works great or doesn't work at all. If driving and it goes out my rover hesitates and stumbles under load until it either starts working again or goes completely out.
Old Mar 27, 2015 | 08:35 AM
abran's Avatar
Sounds like the connections at your alternator or battery.
Old Mar 27, 2015 | 09:13 AM
Jnj's Avatar
Jnj
The tach isn't affect. Only the speedo. I never have any problems with start up or battery dying so not sure it's alt or battery.
I'm thinking its directly related to speedo and sensors
sandnsable
Nov 24, 2011 09:32 PM
Phototone
May 3, 2008 12:15 PM
morfa
Feb 16, 2007 11:19 AM
The Mighty Finn
Jun 20, 2006 01:46 AM
lbvbroker
Mar 4, 2006 01:28 PM
