spongy brakes
Old Sep 27, 2009 | 04:32 PM
tommytwotone's Avatar
Default spongy brakes
Soooo.. My brakes are spongy.
When I press on the brakes they feel very unsecure, sometimes squeek. However if I pump them twice they grab perfect, make no noise but sometimes pull different ways.
My fluid is blackish
My question. Should it just be bad fluid that is causing this or possibly something else?
what should I look at?
Thanks
Old Sep 27, 2009 | 06:09 PM
Do a complete brake fluid flush and then go from there.
LR recommends this every 24 months no matter the miles.
Old Sep 28, 2009 | 09:04 AM
Plan on on using at least 3 pints of DOT 4 fluid, make sure you bleed each wheel as many times as it takes to get all the dirty fluid out of the lines.
By the way, what year is your truck, if it is a D2, get that brake squeak taken care of before you set the 3 Amigos.
lilherc
Jun 7, 2019 08:51 PM
96discofanorvictim
Nov 11, 2013 06:18 PM
Petunia
LR4
Nov 5, 2011 11:30 AM
iownme
Nov 16, 2009 09:51 AM
pc jamie
May 27, 2008 07:31 PM
