spontaneous shifting from 4th to 3ed at constatnt high way speed
Old Apr 16, 2012 | 04:37 AM
Your alternator volts seem OK, but - when truck is not running, and you have that 12.92, what happens when you turn on the head lights? Should not drop like a stone to 11 or less (dead cell).
Old Apr 16, 2012 | 10:02 AM
hhalimi's Avatar
Checked the battery voltage this am and it is 12.42 turned the head lights on and it dropped to just above 12. Dome light was left on the whole night
Old Apr 16, 2012 | 10:05 AM
hhalimi's Avatar
I also tested the TPS with voltmeter and seems to be functioning ok. No skips or gaps
Old Apr 16, 2012 | 10:16 AM
You have a problem, you have to be between 13.6 and 14.4 volts or your ECU's won't work properly.
Tested mine last week and showed 12.65 on one battery and 12.78 on the second, 14.75 at idle with the engine on. Better go verify if your's is a battery or alternator problem and fix it.
If it is the battery, buy one with a rating of 800 CCA's or higher. If it is the alternator, do not buy rebuilt, go the British Parts of Utah for a great deal on a new 130 amp Bosch.
Old Apr 16, 2012 | 11:00 AM
hhalimi's Avatar
The date stamp on the battdry, is this the production date?
Old Apr 16, 2012 | 11:29 AM
No, that is the date installed, why do you ask in that it has nothing to do with your trucks issue?
Old Apr 16, 2012 | 12:49 PM
hhalimi's Avatar
It looks like I need a new battery and the reason why I am asking is because that date 2011. And I thought battery should last more than a year
Old Apr 16, 2012 | 07:30 PM
You went to Canada last weekend right?
It was hot here, was it hot there?
Did you run the a/c on your trip?
The cruise control and stereo? GPS plugged in? Cell phone charger?
All of these things will drain your battery, if your alternator is marginal it will not keep up with the load and the battery will eventually drain.
Here is what I would do, leave it alone until it acts up again, you are just going to be replacing parts to fix a problem that you do not know for 100% is there.
It runs fine now correct?
Battery is full correct?
Drive it and dont worry about it.
Old Apr 16, 2012 | 10:30 PM
hhalimi's Avatar
Not in Canada, but it was hot after we crossed te border and this is when the problem started
Only for few minutes at times. I have a newborn and we did not want the car to be too coldand it was not running when the car finally stalled
Cruise control on disco is junk, it was feeling as if a kid was driving the car constant acelarating and decelarating, no GPS, but kids Ipad was intermittently hooked to get charged
Possible
That's what I am planing on doing, but I will get a $19 CPS and just carry it with me along with the voltmeter
Yes
Yes, it is only one year old and looks like it has 3 years free replacement warranty from advance auto parts
I was bragging to my wife that the car will take us anywhere, but it was a scarry encounter with 3 kids(one new born) in the car, I am glad it happened after we crossed the border and that the car made it home. I will drive it but until I know what was wrong no more long trips in disco. I averaged 14.6 MPG for the whole trip and this is also nothing to brag about.
Old Apr 17, 2012 | 09:15 PM
Your automatic climate control will keep the cabin at a constant temp, thats why it has the numbers on it, set the temp, turn on full auto and forget about it, it will turn the a/c on/off as needed as well as adjust the fan speed to heat/cool the cabin.
So no need to worry about the newborn, besides, you can always cover him/her with a blanket, thats what we do, we have a 5 month old.
