Sport mode MPG
Old Jan 22, 2013 | 07:31 PM
aarongregor's Avatar
Default Sport mode MPG
Okay just ran through a tank of 93 octane gas on sport mode and I got 432 miles and that is with the 3" lift and front and rear HD bumpers. I have never seen over 350 on a full tank before. I got a little over 17 MPG!!! I just filled up again with 93 octane and will run it out of sport mode to see the difference in MPG. I still cannot believe that I got over 400 miles, that has never happened before. I will post the other data when the gas light comes on.
Old Jan 22, 2013 | 08:08 PM
CANAMDiscovery's Avatar
Going to press that little button tomorrow.
Is the majority of your driving stop and go, or highway?
Either way that is impressive. Any idea why?
I realize that sport mode holds gears and may strain our parts, but I can't imagine it being that much of an issue?
As long as we don't drive our Land Rovers like they are a 911, we should be ok?
Old Jan 22, 2013 | 09:17 PM
ZGPhoto's Avatar
I've never got over 300 miles so color me jealous!
Old Jan 22, 2013 | 09:19 PM
CANAM my driving is stop and go and highway. I will be curious to see what this next tank will do without sport mode
Old Jan 22, 2013 | 11:57 PM
souljad9's Avatar
When driving around town, I keep it in sport mode, and get significantly better mileage also. I was told this hint by Trevor at roverlab. Iirc he said it has to do with the transmission shifting less, thereby a lifted truck with bigger tires stays in the optimal powerband more, and not lugging the engine at lower rpm's
Old Jan 23, 2013 | 12:59 AM
re: As long as we don't drive our Land Rovers like they are a 911, we should be ok?
Maybe they are driving like us....
Old Jan 23, 2013 | 01:33 AM
sickws6's Avatar
Man Are you sure all of your injectors are firing? I have never got even 280 a tank and I drive no faster than 65mph mostly highway. Keep RPMs down.
Old Jan 23, 2013 | 05:12 AM
hilltoppersx's Avatar
Keep calm use sport mode
Old Jan 23, 2013 | 07:24 AM
AdrenalinPlease's Avatar
Im hovering around 13mpg mixed driving calculated properly and running on 93 octane. Non sport mode. Will try sport mode now when I fill up.
Old Jan 23, 2013 | 08:04 AM
grandkodiak's Avatar
I ran sport mode consectutively for a few tanks and saw a drop in miliage of about a half to 1.5mpg every tank, doing the same routine and same pedal pressure. I'll post the data when I get home tonight if anyone cares to see. Also did "3rd" instead of D tests and a few others.
