Springs after ARB bumper
Old May 10, 2012 | 09:18 PM
aarongregor's Avatar
Default Springs after ARB bumper
I just put a ARB bumper on my Disco. Can I put spacers in my springs so I dont have my tires rubbing when I turn?
Old May 10, 2012 | 09:21 PM
Yes.
Or you can buy a set of used rear springs and put them in the front.
Old May 10, 2012 | 09:24 PM
Thanks Spike Thats what Wilson is doing< he also bought a ARB and he is going to try that. Is it easy to swap springs?
Old May 10, 2012 | 09:42 PM
Yes installing springs is easy.
Remove the caliper, remove the shock, using a bottle jack press one side of the axle down until the spring can come out, install new spring, put it all back, do other side.
Should only take a hour or so.
Old May 11, 2012 | 10:18 AM
If you plan on wheeling at your mileage, your factory springs have dropped at least an inch and a half and have not strength left in them as well as your shocks and steering stabilizer have long since died.
Using spacers to compinsate for needed height and the extra weigh is a "BAD" way to go.
Spend the money and replace your suspension with a lift and do not use rear or any other warn out factory springs, it is a waste of your time and money.
Drillbit
Aug 17, 2015 12:32 PM
DiscoRover007
Aug 14, 2015 11:46 AM
scottmb23
May 16, 2014 03:59 PM
rchrd0413
Apr 22, 2014 02:18 PM
andrewmcoffin
Feb 19, 2008 10:53 AM
