squeal when cold, maybe not belt
Old Jul 24, 2011 | 08:45 PM
jbarr89's Avatar
Default squeal when cold, maybe not belt
Recently I've had squealing when the engine is cold, I put on a new belt 6 months ago and it's never squealed since I put it on up until a week ago. It started small and only did it for a few seconds at start-up, now it goes on for about 2 minutes. I'm almost certain that it's not the belt, but of course I'm not 100% sure, which is why I am here. I revved the engine a little while looking down at the belt and I smell a faint smell of a burning clutch smell, can a fan clutch squeal like this?
edit:I read some more posts and I'm going to replace the pulleys first, please delete this, I tried but there was no option
Old Jul 24, 2011 | 09:12 PM
Your belt tensioner is bad.
Old Jul 24, 2011 | 09:43 PM
And the fan clutch can't make that smell, it is two metal corrugated discs with "silicone" fluid between. No friction material to burn off under use.
Old Jul 24, 2011 | 09:54 PM
jeffh's Avatar
have you checked to see what the volts are on your battery? It could also be your alternator.
Old Jul 26, 2011 | 07:51 AM
jbarr89's Avatar
no, I will check that also. Thanks!
Old Aug 15, 2011 | 09:38 AM
jbarr89's Avatar
turns out it was the water pump...
zrmcdonald777
Jan 29, 2015 12:30 PM
Nightmel
Jun 1, 2011 12:25 PM
Nightmel
May 23, 2011 10:21 AM
Timpala`
Feb 2, 2010 05:44 PM
01disco2
Oct 3, 2009 07:03 AM
