SRS and Horn
Old Nov 3, 2006 | 12:44 PM
lt4you2's Avatar
Default SRS and Horn
Hi everyone,
I just had my gear box and powering pump replaced (125000 miles) and all went well but then I notice that my SRS light was on. I asked my mechnic about and he said it was already on when he worked on it (which I know was not on). He looked it over and good not find anything visiably wrong with it. And now my Horns don't work at all. Checked relays and they work (also horns go off when alarm is set off). So now I have no horns and SRS is flashing. Any ideas?
Thanks.
Old Nov 3, 2006 | 02:48 PM
Default RE: SRS and Horn
When this happens, there are only 2 things that will cause it, the battery was unhooked too long so the SRS threw a low voltage code or the spiral ring and possibly the horn button have been damaged.
You need to go to a shop where they have eithr Rovers test book or an auto logic scanner to read the codes.
Mike
Old Nov 3, 2006 | 03:50 PM
lt4you2's Avatar
Thank you. I guess I have to take it to a LR dealer.
Old Nov 3, 2006 | 04:55 PM
Old Off Roader's Avatar
Man I hate to see you do that. Where are you located? Maybe I know of a good shop near you.
Old Nov 7, 2006 | 03:22 PM
lt4you2's Avatar
I live in Biloxi, Mississippi. The only LR dealers located nearby are New Orleans, LA. and Mobile, Al. If you know someone in my area that can clear the SRS code please let me know.
Thanks.
Old Nov 7, 2006 | 05:45 PM
CTBRover's Avatar
I had the same problem when i got it. Whomever had it before just pulled the fuse for SRS. I havn't found out what it is either let me know if you do.
sratican
Nov 10, 2010 12:33 AM
lipadj46
Aug 13, 2009 07:47 PM
sallen
Nov 10, 2008 01:22 AM
kindtree
Feb 28, 2008 08:20 PM
red rover 99
Jun 22, 2007 01:30 AM
