Sponsored by: CARiD
srs light on and no horn!
Old Jun 17, 2007 | 10:31 AM
red rover 99's Avatar
Default srs light on and no horn!
Hi there! just had the steering box replaced and on the way home noticed that the srs light on the tach is lit and the horn doesn't work,[&o]Fuse or something diconncted during the repair??? ooops- disco 1 99 rver!
Old Jun 18, 2007 | 08:33 AM
Default RE: srs light on and no horn!
I would take it right back to the shop that did the work, that is their responsibilty to fix.
Mike
Old Jun 18, 2007 | 10:30 AM
Thanks for the super fast reply!!!I am taking it back to my mechanic but I thought that maybe I could give him a heads-up!!!
Old Jun 18, 2007 | 12:45 PM
If he doesn't know, he shouldn't have worked on it. Does he have a lap top scanner so he can access the codes and clear them. I am thinking that he may have damaged the clock spring.
Mike
Old Jun 22, 2007 | 01:30 AM
wardolb's Avatar
your rotary coupling has been broken form when they changed the steering box so therefore your drivers side airbag has been disconnected and also your horn...cause the coupling so controls ALL the buttons on your steering wheel...
sratican
Nov 10, 2010 12:33 AM
lipadj46
Aug 13, 2009 07:47 PM
sallen
Nov 10, 2008 01:22 AM
kindtree
Feb 28, 2008 08:20 PM
lt4you2
Nov 7, 2006 05:45 PM
