SRS light on after being rearended
Old Oct 25, 2008 | 09:37 PM
Willie 00D2's Avatar
Default SRS light on after being rearended
Yesterday I was sitting at a red light and was rearended by a small suv doing about 5 mph. After looking at both vehical's, there was no damage to either other then my plastic LR hitch plug was a little smashed. So after driving away I noticed the SRS light was on. This morning it did not come on during a 20 mile drive. This evening I took it out and the light came on again and I tried to turn the engine off and restart it and the light came on again. Would disconecting the battery clear the code? What could be causing this?
Thank you,
Willie
2000 Discovery II
Old Oct 26, 2008 | 09:10 AM
Default RE: SRS light on after being rearended
I hope you kept the other drivers information. Get it to a shop and have the system scanned.
Old Oct 26, 2008 | 12:01 PM
99% of the time there is no problem, but you do need to get it scanned because when the SRS light is on then your airbag will not work.
Most likely the ECU knows something happened but not sure what and it just needs to be reset.
Old Oct 26, 2008 | 03:28 PM
Because we did not see any damage we did not exchange info. Next time I will get all the info.in case of hidden problems like this one. I willtake it in and have it checked out. Thanks guy's
Willie
Old Oct 27, 2008 | 12:28 AM
tacomatech's Avatar
It probably jarred a crash detection sensor around a bit, and either damaged the connector or damaged the sensor(just guessing without posted fault codes).
jljde
Jun 25, 2012 09:54 AM
DiscoJonny
Apr 28, 2012 07:21 PM
cationmoted
Sep 1, 2010 05:12 PM
Ronco
Nov 29, 2008 07:51 PM
afox04
Apr 28, 2008 10:13 AM
