SRS light problem
Old Aug 9, 2006 | 11:39 PM
bphiggins's Avatar
3rd Gear
Default SRS light problem
So heres the deal. The light comes on and then will go off. First time it came on I unplugged the srs fuse and it went out. Second time it was out for about 230 miles since reset and came on for about 50 miles and went out on its own. Anyone know what gives??
Thanks.
Old Aug 10, 2006 | 04:37 PM
geoman's Avatar
Default RE: SRS light problem
The SRS light can be triggered from multiple sources. One common one is the seatbelt sensor(s)--- the drivers seat mechanism usually gets the most use, so is the more likely culprit. Secondly--- there is a "Clock spring" behind the steering wheel that can throw the error code. You also have accelerometers on the vehicle to sense G-loads in the event of a accident--- these usually don't fail, but check the connectors. And last--- the SRS control module can develop a internal fault. Unfortunately, it is difficult for the owner to diagnose and correct this problem. A shop with a Rovacom or Autologic scanner is your best bet.
Regards,
Mike McLaughlin
http://www.eurotekapg.com/techinfo.html
P.S. If the vehicle was ever in a previous accident that resulted in a airbag deployment, the situation gets sticky!
Old Aug 10, 2006 | 10:31 PM
bphiggins's Avatar
3rd Gear
Thanks for the input. I'll check the seatbelt first. The light is just so random comes and goes, but it seems to come on more when I'm at a half tank of fuel or less.
Old Aug 21, 2006 | 12:24 PM
debolles's Avatar
got a similar random error but to me it seems temperature related (I am in the Middle East)
Old Aug 21, 2006 | 12:31 PM
ORIGINAL: debolles
Temp is usually not a cause for an SRS fault.
Mike
mfryburg
Oct 19, 2008 10:38 AM
robdis96
May 21, 2007 08:05 PM
RJADM2000
Dec 11, 2006 06:59 PM
Rovercountry
Dec 25, 2005 09:42 AM
anonimaus
Mar 14, 2005 12:39 AM
