Stalling/Fuel Pump Questions
Old Jan 25, 2019 | 04:02 PM
Best4x4's Avatar
Second Attempt:
Yep it started right back up with no issues. It would die in D or R. I inspected the IAC (no faults) and it was froze up completely. Removed it, cleaned it until it was free, and re-installed it. Customer thought their transmission was one the way out.
Darn Forum & it’s auto thread revival...
Old Jan 25, 2019 | 04:09 PM
CollieRover's Avatar
Originally Posted by Best4x4
Second Attempt:
Thanks Best! I’ll inspect when I can, it’s two jacket cold out here in Chicago tho.
Old Jan 25, 2019 | 06:22 PM
Best4x4's Avatar
I hear ya & no problem at all!
Old Jan 25, 2019 | 08:16 PM
Spent 1.5 hours in traffic picking up the little fella. No stall. I wonder if I had a bad batch of gas. Probably wishful thinking. Anyway, when and if it warms up I want to take a peak inside the tank.
Old Jan 26, 2019 | 11:12 AM
Saturnine's Avatar
Maybe there is crap in the tank that clogs the pickup tube but then clears once the truck stalls?
Old Jan 26, 2019 | 04:00 PM
Best4x4's Avatar
Yeah I’ve seen nasty pickup socks for sure or units completely gone!
Old Jan 26, 2019 | 08:02 PM
I’m with you guys, i’d Like a visual inspection. I mean, the truck runs fantastic, well, aside from stalling randomly.
Old Feb 4, 2019 | 10:54 AM
She stalled again this morning so I brought her back in. Having fuel pressure checked for peace of mind.
Will update if there is a clear cause, and will likely order a used IACV to swap and test if no clear cause.
Old Feb 4, 2019 | 02:50 PM
All sensors working properly, and fuel pressure is 100%
Going to find a good used IACV to swap in.
Anyone know if a purge valve could cause stalling ? Mine clicks like crazy.
Old Feb 4, 2019 | 03:31 PM
Best4x4's Avatar
Actually I just had my 02 Westminster project suffer from an odd issue. I would run it maybe 20-45min at idle, drive around a bit and when I put it into P the engine would nearly die 100%. It did this several times and one time it popped up with a pending code of P0441. I had two Bosch LR's at my local salvage yard and I got the entire Purge Control Valve for like 8.00 plus tax. I slapped it in & it hasn't done it since. Most of the time it never threw a code until that one time and I had my scangauge II connected and caught it before a key cycle. Up until that freaky business I've never had a Purge Control Valve on a Bosch V8 ever do that.
I've heard plenty click loud (Bosch Unit's), and still work fine, and then I've had them just up and die. I normally always use the Hyundai Replacement vs Bosch, but this time I was able to grab one locally for cheap.
