Stalling/Fuel Pump Questions
Old Feb 4, 2019 | 03:39 PM
  #21
CollieRover's Avatar
Originally Posted by Best4x4
Actually I just had my 02 Westminster project suffer from an odd issue. I would run it maybe 20-45min at idle, drive around a bit and when I put it into P the engine would nearly die 100%. It did this several times and one time it popped up with a pending code of P0441. I had two Bosch LR's at my local salvage yard and I got the entire Purge Control Valve for like 8.00 plus tax. I slapped it in & it hasn't done it since. Most of the time it never threw a code until that one time and I had my scangauge II connected and caught it before a key cycle. Up until that freaky business I've never had a Purge Control Valve on a Bosch V8 ever do that.
I've heard plenty click loud (Bosch Unit's), and still work fine, and then I've had them just up and die. I normally always use the Hyundai Replacement vs Bosch, but this time I was able to grab one locally for cheap.
What’s the info on the Hyundai unit?
Old Feb 4, 2019 | 04:45 PM
  #22
Best4x4's Avatar
Give me a sec & I'll get the P/N for ya
Old Feb 4, 2019 | 04:49 PM
  #23
Best4x4's Avatar
Default Url:
Genuine Hyundai Purge Control Valve
They'll run you 10.00 to 20.00 depending on supply & demand at the time on Ebay.
Old Feb 4, 2019 | 06:35 PM
  #24
Thanks Best! Sorry, I was out and around and being too lazy, distracted to look it up.
Old Feb 4, 2019 | 08:06 PM
  #25
Best4x4's Avatar
Oh no problem, I have it saved from years ago.
Old Feb 5, 2019 | 09:38 AM
  #26
Going to check out and re-clean my IACV today, install the purge valve when I get it.
The Purge Valve tube to the Throttle Body was totally loose when I did my HG job. I have it in there solid now, and I wonder if that is causing the Purge Valve to malfunction because it is actually being used. The pipe was completely losse, would just pull in and out.
Old Feb 5, 2019 | 12:57 PM
  #27
I have the IACV off and gave it a cleaning with Brakekleen and sea foam. You can see on the hose a lot of oxidation which implies moisture and air to me. The other side has zero. I am putting some worm gear clamps on to see if it is simply a vacuum leak here.
Old Feb 5, 2019 | 06:08 PM
  #28
It finally Threw P0440.
Old Feb 5, 2019 | 06:43 PM
  #29
Best4x4's Avatar
Yep that 02 D2 Westminster took forever to toss it and then when it did I knew what to attack.
Old Feb 5, 2019 | 07:08 PM
  #30
Just happy to know what it is.
