Stalling out after start up
Old Sep 17, 2020 | 06:04 PM
CollieRover's Avatar
Default Stalling out after start up
So now the truck is stalling put the battery light, then oil light then the m&a lights start flashing.
What do you guys think? I am checking the wiring.
Old Sep 17, 2020 | 06:05 PM
Just got P1843
Old Sep 17, 2020 | 07:56 PM
Looked up P1843 in the RAVE. It doesn't point to anything in particular. just that moth M&S light up and the truck goes into limp mode. I will have to go through old threads and see what this can point to.
The battery should be ok, but I can get it checked out.
Old Sep 17, 2020 | 08:42 PM
Best4x4's Avatar
P1843 = Transmission Transfer Case Differential Lock-Up Feedback Switch Open Circuit. Only time I've ever seen that pop up was from a low battery or nasty terminals/grounds to be honest.
Old Sep 17, 2020 | 09:40 PM
Old Bertha's Avatar
I'd bet on either the battery, alternator, or both. Only time i have run into MS lights flashing is low battery, and even if it was a low battery, alternator should keep it going so could be the alternator isn't putting out what it should.... I'd say run to the auto parts store and see if you can get them both stress tested.
Although not the same, I had the problem on a jeep where the battery was shot and unless you kept the RPM up, alternator couldn't pump out enough to keep the engine going and stalled, what a bitch to get home lol... After you start try and give it some gas and see if it stays running at a higher RPM
Old Sep 18, 2020 | 04:33 AM
JUKE179r's Avatar
This!
Old Sep 18, 2020 | 08:43 PM
Thanks Best. I got my terminal brush out scrubbed them good with battery termonal cleaner and wired brushed the terminals and posts.
So far so good.
AdrianDiscovery
May 23, 2020 07:25 PM
Kim Sorensen
Mar 23, 2020 08:59 AM
gpRover2011
Jan 11, 2020 06:37 AM
SilverDisco04
Mar 25, 2014 09:11 AM
JakeVT
Feb 19, 2011 11:08 AM
