Starting engine w/ oil pan removed
Old 03-23-2021 | 11:03 PM
nashvegas's Avatar
Default Starting engine w/ oil pan removed
I was way down a Youtube rabbit hole... and found this video.
Starting the engine without the oil pan in... isn't this an absolutely horrible idea? (even if the engine is already damaged) Or is this even appropriate to diagnose something like this.
I changed rod bearings on an e92 M3 and I would have never imagined starting the engine with the oil pan off.
Old 03-24-2021 | 12:02 AM
greisinb's Avatar
Sure seems like a bad idea! Unless somehow they are feeding oil through the pickup tube to get some pressure, even then I have lots of doubts!
Old 03-24-2021 | 05:04 PM
Harvlr's Avatar
Even if they have an external pick up tube, the engine still relies on splash oiling.
gulfstream69xr7 (03-24-2021)
Old 03-24-2021 | 05:22 PM
greisinb's Avatar
That too, I watched it again and could see very clearly in the first 15 seconds of so that the oil pickup is just floating in the air, so no lubrication at all...he thought he had rod knock before...just wait.
Old 03-24-2021 | 08:20 PM
Best4x4's Avatar
I don't even have words for that.......
nashvegas (03-25-2021)
Old 03-25-2021 | 09:33 AM
gulfstream69xr7's Avatar
If that engine wasn't already toast, it is now.
04disco2va
12-13-2020 04:16 PM
rhyslegge
04-14-2020 03:56 PM
charlesnj6
Engine & Internal
06-17-2012 09:23 PM
chargersfan
08-25-2007 12:22 PM
jconway
06-20-2005 03:21 PM
Quick Reply: Starting engine w/ oil pan removed
