Starting engine w/ oil pan removed
I was way down a Youtube rabbit hole... and found this video.
Starting the engine without the oil pan in... isn't this an absolutely horrible idea? (even if the engine is already damaged) Or is this even appropriate to diagnose something like this.
I changed rod bearings on an e92 M3 and I would have never imagined starting the engine with the oil pan off.
That too, I watched it again and could see very clearly in the first 15 seconds of so that the oil pickup is just floating in the air, so no lubrication at all...he thought he had rod knock before...just wait.
