Starting Issue
Just carefully remove the plastic air intake tube from the throttle body, if you look in side the throat of the t/body you'll see the throttle plate and alot of grime. Spray some carb clener on the plate, open the plate using the throttle cable, spray as much of the area as possible, scrub it with a tooth brush, wipe out as much excess grime as you can, reattach the hose and start it up. The engine will take a little effort to start because of all the carb cleaner used but it will start and be happier.
sounds like your stepper motor. The Idle Air control valve might be dirty. The throttle plate seals off you intake and the IAC valve lets air in for starting. If it is clogged, no air.
alsuch
Apr 20, 2008 09:09 PM
Rob84
Feb 7, 2007 08:49 PM
