Starting issues now Code 44
Old May 18, 2009 | 02:38 AM
RamblingMan's Avatar
Default Starting issues now Code 44
Hello,
94/95 D1 with 99K.
A couple of days ago truck wouldn't start. Turn over, sputter a little then die. After a few hours it started up like nothing was wrong. Drove fine around the block. Same thing happened the next day but that time I opened the fuel pump access panel and noticed fuel pump was not turning on when starting. After a couple hours I tried again and this time pump came on and car started up. I went for the cheap fix and put in a new fuel pump relay. The next morning battery was dead (coincident?) After jumping it, then starting it up a couple times, check engine light came on with code 44. This whole time, I drove maybe 2 or 3 miles with probably a couple dozen cranks/starts. I know the code is for an O2 sensor, but I'm hoping its an error related to all the cranking/starting and not driving too far. Could the jump have done it?
RM
Old May 18, 2009 | 08:08 AM
No the jump start would not have set off the code.
Reset the CEL and wait and see.
Old May 18, 2009 | 10:30 AM
Time to replace BOTH 02 sensors, it won't just go away.
Old May 18, 2009 | 06:05 PM
Ok so here is where I am now: I reset the CEL. Now I'm getting RPM drops as I accelerate or just idle. Could the whole thing have been caused by a idle air control valve, throttle position sensor, or idle motor? My huge dilemma is that next monday I'm moving to NY from chicago and if the car can't be driven I have to get rid of it. From what I figure, any parts would have to be ordered Tuesday. Any fix ideas appreciated.
RM
Old May 18, 2009 | 06:16 PM
2 different issues, the 02's won't bounce your idle around.
Old May 18, 2009 | 07:48 PM
Clean the throttle body, remove the stepper motor and clean it and the port that it goes into also.
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
slskier88
Apr 29, 2014 04:14 PM
jclark1012
LR2
Feb 23, 2013 08:27 AM
sayeedA
Nov 15, 2011 11:02 PM
ScottJ
Sep 13, 2007 12:22 PM
