Starting problem
I have a 2002 Discovery 2 that I'm having a starting problem. When I turn the key the 1st time the engine will turn over about i/2 a crank. I wait about 5-10 sec and try again and it will turn about 1 1/2 times, wait about an other 5-10 sec. and it will start. The battery is about 6-7 months old is holding a charge.
Any ideas?
RLS, Saint Paul
Any ideas?
RLS, Saint Paul
Some parts stores can test the drain of the starter when doing a batetry and cranking test. My starter draws almost 300 amps when starting. I used a clamp on meter to test it. You may have a bad solenoid on the starter.
