starting probs
Help!!
When i start my 89 Disco (Auto) it has started to idle roughly. It then calms down,
When I put it into reverse there is no power. Have to put it back into park where it idles properly.
Eventually it goes into reverse and moves, then as i put it into drive the same happens. No power and the idle is rough.
I actually bought this car from my mechanic thinking that it was looked after, maybe i was wrong?
Any ideas?
Any ideas?
can sombody help
I have a intermitting problem every now and then my 300 td 1996 wont start i get a click noise within the passenger footwell so somthing electrical
I had the started motor checked and everything is fine it will start if left alone for a while or if pushed?
Toe
Toe
ORIGINAL: ihami
Hi Mike
Sorry dont know what i was thinking. Car is a Discovery TDi Auto 1995 Diesel.
Hi Mike
Most diesels have a lack of power due to bad fuel or a clogged fuel filter.
Buy a bottle of diesel injector cleaner, dump that into the fuel tank and then have the fuel filter changed. Also check the air filter and see if it is clogged.
Cars from mechanics are the least looked after, they work on cars all day, they dont want to come home and work on theirs for free.
