Starts then stalls
Old 08-21-2015, 08:35 AM
caymandrew's Avatar
I'm certain the IAC plug is correct. I just tried disconnecting the purge vale vacuum, no change.
Any chance the Switch - inertia - fuel cut-off could be my issue here?
  #32
Old 08-21-2015, 10:37 AM
drowssap's Avatar
the inertia switch would kill all fuel, so you wouldn't get the initial start "i don't believe",
it would just crank
  #33
Old 08-21-2015, 02:23 PM
caymandrew's Avatar
What kind of voltage should I be looking for on the connection to the fuel pump? Is the fuel line that goes from the pump to the rail well protected or could it have been damaged in the recovery effort dragging it out of center high?
  #34
Old 08-30-2022, 11:11 PM
TAZZ's Avatar
Default Check waste gate if there is one and I think ecr and MAF are the main issuesolution
Originally Posted by june82000
Have you tried disconnecting the purge valve vacuum connection to the intake to see if that code goes away? Of course, when you do, you'll have to temporarily plug the open connection on the intake.
Check waste gate if there is one and I think ecr and MAF are the main issues solution
Needs a bigger hammer 🔨
MurphyPeoples
03-11-2015 06:01 PM
jthomas
05-13-2013 03:08 PM
mapesw
10-01-2010 10:17 AM
Dirt
04-03-2010 04:59 PM
splbrad
10-27-2007 02:49 PM
Quick Reply: Starts then stalls
