Sponsored by: CARiD
Stalls when driving & No starts
Old Oct 16, 2007 | 05:13 PM
splbrad's Avatar
Default Stalls when driving & No starts
I have a 96 Land Rover Dicovery with a 4.0L automatic with A/C.
My problem is it will die when driving some times and won't re start, the fuel gauge on the injector rail says it has 40 psi while cranking, there is no injector pulse (Noid light)or spark to the plugs (spark plug tester) when this happens.
I let it sit for awhile then it will start again and act like nothing is wrong.
The other problem it does is when I go to start it some times it won't start, and what I mean is the dash lites up but it gets no power to the starter. (tested with a volt meter) If I hold the key in the start postion it will start to crank after about 5 sec. but no spark or injector pulse. The fuel test gauge tells me it is not the fuel pump.(gets voltage via a volt meterand it also shows up by the gauge needle jumping from 38 psi to 40 psi)
The crank sensor is testing good on a Snap-On Vantage the wave looks good. The dealer I took it to say it need an ignition module in the distributor, but the system is a D.I.S. No distributor.
I think it is a module, main relay acting up, or a coolant temp sensor to the ECM(not the dash gauge sensor).
Any help will be great.
Old Oct 18, 2007 | 07:19 PM
dirtyduk's Avatar
Default RE: Stalls when driving & No starts
This sounds like a can of worms, something is loosing continuity when hot, look at the engine grounds and ECU grounds on the pass side.
Also inspect the GEMS ECU mounted on the pass side inner fender for water ingress, look at the plug pins and open the ecu to see if water has corroded the circuit boards. If your loosing injectors and spark you must be loosing the input (crank sensor ) or the ECU . Any Codes stored ?
Old Oct 19, 2007 | 06:51 AM
Landzu's Avatar
On the fuel rail there is a fuel temp sensor, this maybe your
problem.
Its on the left side just in front of the intake, it does not go into the
fuel rail so no problems with taking it off, or gas leak problem.
Old Oct 27, 2007 | 02:49 PM
splbrad's Avatar
All right I found the problem the computer was losing voltage, the wire that feed the computer had to much resistance and would drop below 12v at times.
Thanks for all the help.
B.Higgins
caymandrew
Aug 30, 2022 11:11 PM
jthomas
May 13, 2013 03:08 PM
mapesw
Oct 1, 2010 10:17 AM
Dirt
Apr 3, 2010 04:59 PM
RJADM2000
Oct 4, 2006 11:49 AM
