steering box play
Old Feb 14, 2025 | 01:09 PM
  #21
H20nSnow's Avatar
Originally Posted by mackendw
I disconnected the track rod from the pitman arm ...made a nice SNAP sound when it broke loose.
Tightened the adjustment screw another 1/4 turn...and I think that is too far. Am felling some binding when moving lock to lock.
The bump is still being felt with the drag link disconnected...so it HAS to be steering box then....correct?
You can still disconnect the steering shaft from the input of the box. With both input and output disconnected if you still feel the clunk then you have definite proof. And, you’ve done the work to R&R the box. Win win.
Old Feb 14, 2025 | 02:49 PM
  #22
mackendw's Avatar
just took it out for a run...steering is a bit too tight for my liking. Don't like the heaviness introduced. I'll live with the bump at 12:00 for now..
saving my $$ for a new steering box I guess....
Old Feb 15, 2025 | 09:08 AM
  #23
redrover75's Avatar
Default Steering box
I have a steering box you can have if you want. It is a slight leak, but works fine. The seal kit is cheap of you want to fix it.
Old Feb 15, 2025 | 09:33 AM
  #24
mackendw's Avatar
that is very kind of you! I wonder what the shipping charge would be on it to 33778?
I have a new OEM upper radiator hose and 2 thermostats I could swap it for? grey and cream colored ones.
Old Feb 15, 2025 | 05:27 PM
  #25
Extinct's Avatar
I have a 2 thermostats I could swap it for? grey and cream colored ones.
I would not do that to that nice man
Old Feb 15, 2025 | 05:47 PM
  #26
mackendw's Avatar
ha....you're gonna get me in trouble
Old Feb 15, 2025 | 06:21 PM
  #27
mackendw's Avatar
btw...that inline thermostat is working superbly.
my son's 2000 with the 4.0L ...he has one too...he just installed a flokooler water pump in and is running in the high 160's.
Old Feb 16, 2025 | 06:15 PM
  #28
redrover75's Avatar
It looks like fedex ground is ~$70. open to any suggestions. I put in a weight of 40lbs, probably about right?
Old Feb 16, 2025 | 07:16 PM
  #29
mackendw's Avatar
do you know where/how bad the leaking is occuring. I watched a few videos on repairing the seals on the input/output shafts. I think
I could handle that.
when the box is centralized, is there any play in the input shaft? That is where mine is worn.
Old Feb 17, 2025 | 09:13 AM
  #30
redrover75's Avatar
Default Box
I had no play, it was actually tighter than the one I put in. I'm not sure whee the leak is, simply nailed down the leak to the box and replaced it. I agree the repair looks manageable.
