Steering damper
I guess we will all find out together, but i'm guessing someone sells an OEM damper.
OP says he is running a billstein now, so i guess they must make one.
I think Zack at Rovers North also mentioned a damper that was RTC the last time this came up
TF does make a TRC (Coil Spring over the damper), but I don't think it's for the disco. (female to female)
Also, check a discussion here...no fix posted. yet.
https://landroverforums.com/forum/di...-damper-56508/
The TF835 is for the Defender and can be fitted to a D1 or RRC using the TF retrofit kit.
You would have to custom make something for the D2.
What aspect are you trying to upgrade? Are you having some sort of problem that you are trying to correct?
Someone with some intelligence! Thanks for bringing this back on track. It gets frustrating when people just start giving information without any knowledge of what they're talking about. Lets help get the OP some proper answers.
The only upgraded Dampers that I know of are TF, OME, or Bilstein.
