Steering damper installation
Old Apr 12, 2016 | 01:30 PM
batard's Avatar
Default Steering damper installation
Dumb question, but I don't have to lift the front of the vehicle to swap in a new steering damper, right? RAVE says you should, but I can't see why it's strictly necessary. Seems like an easy job.
Old Apr 12, 2016 | 01:45 PM
galchutt81's Avatar
Good question I just ordered mine and it'll be here in a week. As it looks there is plenty of clearance you shouldn't have to lift it to install.
Old Apr 12, 2016 | 01:59 PM
acg's Avatar
acg
I recollect installing a Terra Firm damper a couple of years ago without lifting the truck. You simply compress the damper and get it to fit within the mounting holes.
Old Apr 12, 2016 | 03:11 PM
batard's Avatar
For reference, I just installed it without lifting the vehicle. It seemed to go in ok, although getting the bolts lined up in the new one's holes was a little awkward.
I don't need to get an alignment after doing this, right?
Old Apr 12, 2016 | 09:54 PM
acamato's Avatar
Your are correct. You do not need an alignment.
thehun
Mar 10, 2011 08:11 AM
N.Franklin
Nov 13, 2007 08:06 PM
Fonzie
Nov 1, 2007 08:55 PM
RedElephant
Jun 3, 2007 07:31 AM
anonimaus
Oct 29, 2005 06:22 PM
