steering noise
Old Feb 27, 2012 | 07:50 PM
hhalimi's Avatar
Default steering noise
My steering is makeing a grinding type noise only in one location when turned to the right. Each turn of the steering at the same spot causes a grinding noise, some times loud some times not so loud. No noise when turning to the left. And again the noise is at the same spot after 380degree turn of the steering wheel and not continous.
Any idea what it could be?
Old Feb 27, 2012 | 09:10 PM
It is coming from the steering wheel?
Bad clock spring.
Old Feb 27, 2012 | 09:36 PM
hhalimi's Avatar
Originally Posted by Spike555
It is coming from the steering wheel?.
Not the wheel itself, but it is some here in the column, I thought it might need lubrication, local indy couldn't tellme exactly what it was but said if you want it to go away, you will need a new steering linkage
Bad clock spring.
What is a clock spring?
Old Feb 28, 2012 | 06:58 AM
slanginsanjuan's Avatar
has a few names. i forget them. the bad clockspring sometimes releases threads of metal. check around the column seams to see if there is any metal threads coming out. mine was a mess too. i removed it. now i can't honk. but, my truck makes a screetch turning left which i think is a hub problem at this point. but i can tell its coming from the wheel. power steering fluid is fine i assume?
Old Feb 28, 2012 | 09:00 PM
I didnt mean the actual steering wheel making noise, but the gap between the column and the wheel, that is where the clock spring is.
That is the "spring" that sends power to the horn buttons, cruise buttons, airbag...anything that is on/in the steering wheel.
To replace it, remove the steering wheel.
Old Feb 29, 2012 | 12:55 AM
hhalimi's Avatar
Thank you spike, the grinding noise from engine is worrying me more now than the steering noise. I have to find out what is causing that noise and hope the engine won't just stop.
Old Feb 29, 2012 | 04:25 AM
All the way against the stop would be the power steering complaining you are holding the steering at max either left or right. See attached for breakout of steering linkage, be sure bolts 13, 14, & 18 are tight, spray 12 & 19 with PB Blaster or some type of spray penetrating oil (no grease fittings).
21 is the "clockspring" rotary coupler.
This is also something where you could hold a stick (broom handle, long screw driver, mechanic's stehoscope) between your ear and suspect parts and have some one turn the wheel slowly; much easier to hear over the rest of the engine noise. Do same with power steering pump and steering box.
File Type: pdf
david4ducati
Mar 1, 2015 07:59 PM
30more
May 28, 2012 05:01 PM
Robbo
Jun 15, 2005 05:03 AM
adrianwood
Freelander
Jun 13, 2005 08:53 PM
