Steering Wheel removal
Have you removed the torque bolts on the back side? https://landroverforums.com/forum/di...steering+wheel
It helps if you spray a little bit of PB blaster to help loosen it. But you need to try hitting the steering wheel at the 3 o'clock and 9 o'clock positions in a quick, rapid, back and forth manner. Reason being that there is a spring inside. Use something like a rubber hammer, and make sure you hit it from the BACK. As if a midget goblin was trying punch at it sitting from the driver side floor board.
It might take you a while. But it only took me so long because I realized I was hitting it from the wrong side lol.
Granite Disco
02-28-2009 06:48 PM
