Steering Wheel removal
Old Nov 8, 2012 | 12:06 PM
Turtlep's Avatar
5th Gear
Default Steering Wheel removal
Can anyone give me directions in how to remove and replace steering wheel
ihave removed airbag and nut to post but can not seem to get the seering wheel off and see no way to put a puller on
Old Nov 8, 2012 | 12:20 PM
lr2001silver's Avatar
Banned
Have you removed the torque bolts on the back side? https://landroverforums.com/forum/di...steering+wheel
Old Nov 8, 2012 | 02:13 PM
Turtlep's Avatar
5th Gear
yes but how does it come off the shaft
Old Nov 8, 2012 | 02:39 PM
DiscoRover007's Avatar
It helps if you spray a little bit of PB blaster to help loosen it. But you need to try hitting the steering wheel at the 3 o'clock and 9 o'clock positions in a quick, rapid, back and forth manner. Reason being that there is a spring inside. Use something like a rubber hammer, and make sure you hit it from the BACK. As if a midget goblin was trying punch at it sitting from the driver side floor board.
It might take you a while. But it only took me so long because I realized I was hitting it from the wrong side lol.
bmeier
Jul 26, 2014 08:10 PM
Granite Disco
Feb 28, 2009 06:48 PM
The Image
Jan 5, 2008 05:43 PM
humanatek
Sep 24, 2006 08:25 PM
dma3
Feb 21, 2006 01:23 AM
