steering wheel removal
Old Jul 26, 2014 | 03:13 PM
bmeier's Avatar
Default steering wheel removal
Hello, I've pulled steering wheels before on other vehicles. I have to pull mine off of my 2004 D2. Anything special i need to do? thank ya,
Old Jul 26, 2014 | 03:36 PM
acg's Avatar
acg
Make sure steering wheel is centered.
Disconnect the battery first to prevent the airbag from accidental popping.
Remove the plastic steering column cover which is held by 3 screws.
Remove the two Torx bolts behind the steering wheel. Be careful not to strip the heads of the Torx bolts.
Be careful when taking off the airbag module (not let it hang on the harness) and the rotary coupler ($300+ for a new one).
RAVE has detailed instructions on the removal procedure.
Old Jul 26, 2014 | 04:59 PM
Paul Grant's Avatar
The two torx bolts (T27) are buried pretty deep into the back of the steering wheel. The typical torx socket is not quite long enough to reach. You may need to find a longer torx socket. You can use one of those torx kits that look like a Swiss Army knife with a variety of sizes. Just make absolutely sure you have the right size torx because, as acg said, you don't want to strip the head of the bolt.
Old Jul 26, 2014 | 05:06 PM
zski128's Avatar
One more set of instructions for good measure
Old Jul 26, 2014 | 06:59 PM
bmeier's Avatar
cool, very helpful info. thanks guys.
Old Jul 26, 2014 | 08:10 PM
OffroadFrance's Avatar
Spot on Paul. I use these but there are similar sets around. Brueder Mannesmann Werkzeuge M18190 Coffret de 16 clés à manche T: Amazon.fr: Bricolage
Turtlep
Nov 8, 2012 02:39 PM
Granite Disco
Feb 28, 2009 06:48 PM
The Image
Jan 5, 2008 05:43 PM
humanatek
Sep 24, 2006 08:25 PM
dma3
Feb 21, 2006 01:23 AM
