Steering wheel shake at 45MPH
Old May 23, 2017 | 03:06 PM
zoltan7's Avatar
I eyeballed them to get close to the links I took off (not sure if that was stock or not). Sway bars and end links shouldn't have this effect.
Old May 23, 2017 | 03:19 PM
Rover_Hokie's Avatar
I set mine to match what I took off as well, but those were stock sway bar links with no lift at all so wondering if that may be making things a little stiff/tight and causing some issues with a smooth ride. As I added my 1" spacers this past weekend, I disconnected the front sway bar links while I do some homework on what length I may need to set them to. Mine rides like tires are out of balance over 60MPH and I just had the tires installed.
The tires are larger and have a more aggressive tread pattern, so that probably contributed to it as well. I am going to have balance checked again, and set the sway bars to a longer length when I reconnect them. Then I will probably get a new alignment after additional lift and larger tires, probably need it since it has been a few years & a few off-road trips ago since I have had it aligned, but I had no problems before the new tires.
Old May 23, 2017 | 03:35 PM
zoltan7's Avatar
I just checked and my panhard is adjustable lol so that swivel isn't likely bad. The bushing on the passenger side might be bad though.
I think I'll let out a little pressure on the sway, but that still shouldn't result in shake while driving. Something else has to be bad down there
Old May 23, 2017 | 03:52 PM
zoltan7's Avatar
The bend on that end link could be a bit of the problem
er1c
Oct 10, 2013 01:20 PM
DIIZ
Aug 18, 2013 02:47 PM
jeffh
Jan 20, 2011 12:35 PM
Beachnrover
Aug 7, 2010 09:11 AM
Claws
Jul 30, 2010 09:27 PM
