Steering Wheel Squeak
Old Nov 2, 2009 | 08:34 AM
kenk's Avatar
Default Steering Wheel Squeak
I've been noticing as it's getting colder a squeak in my steering wheel. I thaught it was the wheel rubbing on the column shroud, but it turns out it's down where the column goes through the firewall. There's a plastc/rubber?? shroud I suppose is to seal out air/grime/etc. If I push up on it and turn the wheel, it dont do it.
Long story short, I'm gonna try spray lube on it first, but if it continues, would it hurt anything to remove or trim it?
Old Nov 2, 2009 | 08:39 AM
Lube it with silicon spray, it wont attract dirt.
If you trim it/remove it all that will happen in water/dirt/road grim/smog/bugs...everything it keeps out will be let in.
It will not hurt anything at all.
Old Nov 2, 2009 | 09:49 AM
alanroberts50's Avatar
I thought I was the only one Mine just started up again with the colder weather.
Old Nov 2, 2009 | 08:35 PM
kenk's Avatar
Thats when mine started, when it started getting cold at night. The silicone spray worked, But for how long???? We'll see
MrValingo
May 15, 2015 09:43 PM
swak6287
Mar 27, 2015 11:04 PM
TheUninformedOwner
Freelander
Mar 26, 2009 11:39 AM
dodge_mich
Feb 24, 2008 09:40 PM
klh113
Sep 18, 2007 10:34 AM
