Stereo Install
Old Nov 19, 2008 | 12:46 PM
jbremser's Avatar
5th Gear
Default Stereo Install
I have a 95 disco and i and trying to get the factory stereo out without destroying it. Is there a tool for the two little holes on the side in order to get it out in one piece? If there is a tool where can i find that tool.
Old Nov 19, 2008 | 01:11 PM
Urban Panzer's Avatar
Default RE: Stereo Install
Hi,
You will need a set of these removal keys
Should be able to get them a any good auto store / car hifi place
Old Nov 19, 2008 | 01:12 PM
Jull's Avatar
I stuck an allen key in the two little hole in the front, and when I felt that the radio was loose, I pulled it out. I planned to install an aftermarket stereo in my disco but I forgot about it when I saw the bunch of wires behind the factory one...
salve7's Avatar
What you need are two "Alpine" stereo removal tools which can be picked up on ebay (which I did for about 4 bucks) or I am sure you could get them or maybe even borrow themfrom an audio shop. The first time you take the stereo out it can be a little tricky. I had to get two wrenches and tug like a mad man (not unlike my personal life). There is a detailed explanation on here somewhere with pics as a guy installed an Ipod interface.
Old Nov 19, 2008 | 01:21 PM
ORIGINAL: salve7
but he has a D1 not a D2............they are not fitted with the Alpine Headunits
Old Nov 19, 2008 | 01:29 PM
salve7's Avatar
I didn't think it mattered which brand of tool/ radioyou used/ had. I just found them because they were cheap. If I could do it over again I would of just made some.
Old Nov 19, 2008 | 01:42 PM
All different radio manufacturers use different "keys" to remove thier respective units. The flat ones you mention are for the Alpine headunits fitted to the D2. The D1 had Philips and clarion units andthey have 2 holes each side as opposed to the 2 slots that the Alpine has a the top. So for the D1 you need keys like the picture I posted further up the topic, they are like the "original" type DIN removal tools.
Nowadays the manufacturers use all diff variations of the flat keys like the Alpine ones, but they are all "slightly" different. My factory Becker NAV unit uses flat keys, but they are half as long and fatter than the Alpine ones for example. Not many (if any) still use the DIN keys like the D1 had as they are "easy" to replicate using allen keys or small screwdrivers, so they were easy for thieves tosteal the stereos even without the correct tools
Old Nov 19, 2008 | 03:10 PM
AK Rover's Avatar
I have a D1 that has just one removal hole on each side of the radio face. I believe that it is made by Pioneer but not positive. I do know the CD changer under the passenger seat is made by Pioneer. I am looking for tools to remove my radio also so I can install the direct connect cable for my Sirius Radio,
Old Nov 19, 2008 | 04:41 PM
salve7's Avatar
Well then oops... I guess the only D1 I have been in had a different radio. In that case ignore me.
instg8r
Jun 2, 2019 05:07 PM
Motorvated
Aug 11, 2013 04:57 PM
Yeti
Jan 19, 2013 06:02 PM
aguison
Sep 23, 2012 05:11 PM
Classklown90
Oct 23, 2009 09:05 AM
