Sticky Ignition
Old Jan 23, 2008 | 01:36 PM
wesk's Avatar
Default Sticky Ignition
Odd thing happened yesterday. I turned ignition, it started, but stuck a little. Meaning the key in the ignition stuck in the "start" position. Therefore it continued trying to start, after it already fired. If I back the key off after it fires, it's fine. So basically i'm manually returning the key to the 2nd position, it's not going there on it's own.
Thoughts, suggestions? Thanks guys.
Old Jan 23, 2008 | 01:51 PM
okdiscoguy's Avatar
Default RE: Sticky Ignition
use the graphite lube only on the lock mechanism, WD will mess it up.. Might be getting time to replace the ignition switch. Take all of your other keys off your keychain. The switch went out in my bro's Cherokee, and he couldn't figure out why. I knew as soon as I saw his wife's keychain. It had the rear metal pad from a tap shoe on it..... Heavy keys wear out the cylinder.
Old Jan 23, 2008 | 01:55 PM
wesk's Avatar
Will try graphite. I only have 4 keys and nothing else. Nothing fancy, just keys.
will rocket
Off Topic
Sep 12, 2013 06:23 AM
1998DiscoverySE
Jun 27, 2012 01:56 PM
FriscoDisco
May 6, 2009 08:30 PM
Philhowe
Mar 6, 2008 11:58 AM
supra92
Jul 13, 2007 07:44 AM
