Stiffer D2 Swaybars
Old Dec 30, 2007 | 12:47 PM
ajh's Avatar
ajh
Default Stiffer D2 Swaybars
Does anyone know of an aftermarket swaybar that will be stiffer than the stock D2 bars? Looking for about a 50-80% increase in torsional rigidity.
Old Dec 30, 2007 | 03:19 PM
Default RE: Stiffer D2 Swaybars
The ACE sway bars, they are huge, and you should be able to make the few changes necessary to make them work.
Old Dec 30, 2007 | 05:13 PM
ajh's Avatar
ajh
Wow, so obvious! I'll have to take a look, hopefully they fit into the appropriate stiffness range! Thanks, you're the first one who even thought of that on any of 4 boards.
Old Dec 30, 2007 | 06:34 PM
By size, the ACE bar is probably 50% larger in diameter.
DiscoWest
Jan 7, 2014 03:56 PM
