Still looking for dimensions of roof rail extension drill guides
Old Jul 27, 2016 | 03:08 PM
austinlandroverbill's Avatar
Default Still looking for dimensions of roof rail extension drill guides
Hi, I have been posting this same requestoccasionally, hoping that someone can help me.
I picked up some roof rail extensions a while back: I have a 2004 but converted from the fat rails to the skinny ones.
Ideally, it would be great if someone had the drill guides for these extensions that I could buy or borrow.
However, lacking that, can someone perhaps at least provide me the dimensions/specs for the guides and maybe I could make my own out of some aluminum stock?
Any help would be greatly appreciated.
Old Jul 27, 2016 | 03:56 PM
abran's Avatar
Im about to part out a D2 with them. I am going to cut out the roof sections for the buyer, but before that I can make some templates for you.
Before you get too excited, its a few weeks away.
Old Jul 27, 2016 | 04:11 PM
Racer X's Avatar
Man, they sure didn't make this easy to find. See the attached PDF.
File Type: pdf
Old Jul 27, 2016 | 05:21 PM
2004D2's Avatar
Was converting from the fat rails to the skinny rails just a simple swap, i.e - same holes, just remove fat ones and replace with skinny ones?
Old Jul 28, 2016 | 08:49 AM
Converting the "base" rails from fat to skinny is simple and the two types are "pin compatible", however, LR made optional skinny rail extensions that ran all the way to the back of the roof, and make the roof rack more useful.
There are no predrilled holes at the back of the roof, so there is a guide template that allow you to properly position the holes.
Old Jul 28, 2016 | 08:55 AM
You see that "thing" in step 3 of the pdf that Racer X posted? That's the drilling guide I need or at least the measurements abran offered to get and send me.
Old Jul 28, 2016 | 01:43 PM
2004D2's Avatar
Thanks for the feedback.
Old Jul 28, 2016 | 02:51 PM
mln01's Avatar
Couldn't you just connect the extensions at the front end and then mark where the screw at the rear end contacts the roof? You're drilling from the top.
Old Jul 28, 2016 | 04:13 PM
BackInA88's Avatar
Fig 4 shows using the drill guide in a hole in the reinforcing structure from the inside to drill a 4mm hole.
Fig 5 tape on the outside to reduce the paint chipping when the drill breaks through.
Fig 6 use the new 4mm hole to pilot the 34mm hole saw.
Fig 7 use touch up paint on the exposed metal to prevent rust.
A 34mm hole should give you plenty to room to dial it straight?
Old Jul 28, 2016 | 06:46 PM
mln01's Avatar
Okay, I get it now. I looked at the PDF too quickly before.
