Still Spongy.
Old Oct 11, 2012 | 11:11 AM
Rover_Hokie's Avatar
Mike,
I replaced the 4 brake hoses at the wheels with stainless steel reinforced hoses. Where are the other 2 hoses located, and where can you get those 2 hoses in stainless steel? Is there a special name for those other 2 hoses, that ID them as different from the wheel hoses?
Old Oct 11, 2012 | 11:50 AM
drowssap's Avatar
one would be in the rubber hose in the rear going from the body to the diff.
I dont remember if the front is setup the same or if the run down the body and out to the wheels.
Old Oct 11, 2012 | 02:02 PM
The other 2 are located along the fire wall under the master cylinder area.
I need to go find the name of that supplier, I'll get back to you.
Old Oct 11, 2012 | 05:15 PM
mx468's Avatar
I recently did the abs fix and my brakes were spongy. The solution which worked for me was, first bleed at the module, than bleed all your brakes. Great time to do a full brake fluid flush. Pedal is firm and brakes work great!
Old Oct 11, 2012 | 06:42 PM
lilherc's Avatar
Problem solved guys thx. I bleed the the whole system, probably some left over air bubbles some where.
Thx again.
Old Jan 25, 2019 | 12:03 AM
Nick Nicolas's Avatar
Default 2003 ranger rover soft pedal
Replaced all 4 brake pads and bled all 4. Now I have a soft pedal and even softer pedal when engine is running also noticed the engine idle changes after pumping the brakes and a sound of air and fluid running through 2 pipes connected to black Box label BOS CH. Can someone with more knowledge please help thank you in advance.
Old Apr 20, 2019 | 04:49 PM
lorryguy's Avatar
I am having the exact same problem after replacing the brake fluid reservoir and bleeding the system (following the Atlantic British youtube video). Not sure what I'm missing here. The system was originally bone-dry after being left sitting (and leaking) for the winter months. Did you find a fix?
Old Apr 20, 2019 | 05:16 PM
Best4x4's Avatar
Power Bleed it
Old Apr 20, 2019 | 05:39 PM
zuke's Avatar
Hey, I just got mine back up and going today with the help of mollusc. I changed out my abs modulator and could not get pedal. I bled the front line going into the modulator then bled each wheel per the rave which I still think is backward or a misprint. Took the truck around the block in low with hill descent on and sped her up then let off to work the pump. A half dozen times. Then bled the wheels again in the right order. RR, LR, RF, LF. Good to go. I don't mean ok good. I mean throw you through the windshield good. Just have patience. It takes awhile to get pedal.
Old Jun 7, 2019 | 05:05 PM
Gebo's Avatar
I am having a similar problem on 97 Disco I.....very spongy brakes after replacing master reservoir, bled brakes 3 times already and it only seems to get worse. Did it both methods, one with helper pumping pedal and solo method with suction tool. What is this "hill descent", I don't seem to have that feature. Also mine will not go into 4 low. Advice needed.
