Still squeaking (video)
Old 11-10-2016 | 09:51 PM
shady milkman's Avatar
Would the flex plate still squeak like that even when the rover is stationary?
Old 11-10-2016 | 11:24 PM
Charlie_V's Avatar
Mine did, but faintly. When the engine is running and the truck in park, the flex plate will be turning because it is connected to the crankshaft, but when you put it in gear the force will increase (not just torsionally, the torque converter also moves forward and aft), and even moreso when you are under way. That causes the plate to flex and if it has cracks, then it can (and in my experience, WILL) squeak or just shatter. Honestly, in my case the flex plate squeak did sound just like a screwed idler pulley, but it was coming from the back.
I'm really sorry I even mentioned it. I have crawled in every nook and cranny of a Land Rover Discovery II many times but I am not a mechanic, or more correctly: I am a terrible hobbyist mechanic and you can verify that in the forums because I always report my mess ups. I could be wrong. Having said that, if you are sure it is from the back and it gets louder at times when the flex plate would be flexing, then that is probably the issue.
It did occur to me that your u joints in the front driveshaft could have a problem but if the squeak is present when the truck is stationary, that's not it. If there is truly no squeak when it is stationary then I have another test for you but I need to know what year your rover is (whether it has a locking CDL, whether you have the linkage or not). If there is only squeak when you are moving and you can lock your CDL either manually or with the shift lever, then you could take 8 nuts off, remove the front driveshaft, and drive it around the block on the back driveshaft only. If the squeak disappeared, you would just need to get the front driveshaft rebuilt and slap it back in (or get a new one), which is a lot cheaper and easier than replacing a flex plate. You would be ten kinds of pissed at me if you spent to get the flex plate replaced and there was nothing wrong with it.
Old 11-12-2016 | 05:52 AM
The Deputy's Avatar
First off...Removing the oil pan will not allow you to see any protion of the flexplate. The flexplate is located between the flywheel and torque converter and without being disassembled can only be seen through the small round plate located at the bottom of the bellhousing.
If you want to check the flex plate, remove the round cover on bell housing (three small bolts), turn engine by front crankshaft bolt until you can see one of the torque converter bolts directly at the bottom of rotation. Then have someone hold the crank bolt, while you use a prybar through the opening to pry the torque converter from side to side (rotation direction), and see if there is any movement and listen for any type of clicking/cracking noise. There should be none, movement or noise.
Before doing this method, you could slide underneath with a piece of hose and listen to the area while running in neutral, then running in gear, and the have someone move it from neutral to drive, seeing if the noise changes and is coming from that specific area. Just be sure that the person sitting inside holding the brakes or applying the parking brake likes you...and definitely don't use the wife...this is an insurance policy claim in the making...lol. No, seriously, just chaulk/block the wheels, apply parking brake (assuming its in working order) and have someone keep their foot firmly applied to the brake pedal. Or do the job with the vehicle on jack stands, just stay away from any moving parts. The noise "should" change with the added resistance of being put in gear.
Good luck,
Brian.
Old 11-12-2016 | 08:34 AM
Charlie_V's Avatar
Brian is right. I was misremembering. I have unbolted the flex plate from the oil pan area rather than the access hole on the passenger side because my bad shoulder gets me more leverage in the former location. But when I did that, I was staring at the back of the flywheel. My apologies. I work on other hobby vehicles and I forgot that the Rover flywheel is a solid disk rather than spoked.
if memory serves, Brian has been a mechanic since I was 10 years old--and I turn 50 next year-- so I hope he will continue to contribute to this thread and also look back at my posts pointing to the flex plate as the possible source of squeaking; I was reluctant to suggest it and hope to be wrong.
Old 11-12-2016 | 06:12 PM
The Deputy's Avatar
No harm, no foul, Charlie. Just pictured the "milkman" taking off the oil pan...and find the flywheel...instead on the flexplate. Not an easy task, for sure. It wasn't my intention to come across harshly, my opologies if it did...darn internet is a tough gig sometimes.
Noises and vibrations are two of the most difficult problem areas to nail down. Especially, on a aluminum block motors; noise really transmits easily through aluminum.
Nothing wrong with pointing the "milkman" in this direction, could very well be the problem. If I was him, I'd drop the belt off (even though parts aren't that old) and give it a good listen. You have to totally eliminate as many possiblities as possible, these darn things can turn into a money vacuum quickly.
Brian.
Old 11-13-2016 | 11:46 PM
Charlie_V's Avatar
Brian.
No foul taken. I was in the middle of a week long cold and my brain was wooly.
I second dropping the belt. I did that once trying to find a squeak and my crank pulley was pushing out its damper and wobbling about a quarter of an inch! The main pulley was making the squeak! Aside: crank pulleys are expensive. Luckily I had a spare from a parts rover.
ge234
11-19-2015 10:14 PM
starcraft
09-25-2007 03:43 PM
Aquaholic
04-08-2007 11:55 AM
sna77
02-09-2007 08:00 PM
mgfung
Freelander
12-29-2006 03:22 PM
Quick Reply: Still squeaking (video)
