Strange door issue
Old Nov 21, 2019 | 07:38 PM
markwemple's Avatar
Default Strange door issue
So in replacing all the actuators in my doors (the main 4 anyway) I found that I was able to get the rear 2 working perfectly. On the front doors, if you lock then unlock (using the central locking button), you can only open it from the outside. Once I open it from the outside, it's back to working normally. I did this several times and I used the central locking button to lock it. Again, if it is unlocked and opens from the outside, the inside works perfectly too. Only once you lock it does it act up.
Old Nov 23, 2019 | 03:15 PM
Extinct's Avatar
Bizarre, never seen that.
Old Nov 23, 2019 | 09:19 PM
markwemple's Avatar
Got the driver's side working but now the pass won't open at all
vgpacer70
Aug 12, 2017 10:09 PM
Disco__Stu
Jun 18, 2014 09:36 AM
corbinwalp
Jan 18, 2014 09:33 AM
Dottieshusband
Jan 24, 2011 02:54 PM
ctk111
Jun 11, 2010 01:44 PM
