Strange issues
Old Nov 28, 2018 | 06:41 PM
m^2's Avatar
m^2
8th Gear
Okay, thanks for the clarification. I changed wires recently (less that 500 miles). After a bit of thought I agree with you on coils, the wires cross over in back duh! I will probably do them anyway though just to get them done when I have time. When I changed spark plugs recently there was no evidence of a head gasket issues (all spark plugs looked the same after pulled) I will top off coolant, but isn't the whole idea of an overflow/expansion tank to allow air trapped in system to fill the tank, and thus still have the active part of the system full?
I am planning to change transmission fluid in a week or two here so that will be filled back up to spec.
I will try disconnecting O2 sensors and test if I can get time when its not stupid cold out. I know that you aren't supposed to test these with a volt meter, I do have a nice scan tool, which readings should I be looking at on scan tool?
Old Nov 30, 2018 | 07:35 AM
m^2's Avatar
m^2
8th Gear
So a bad sign this morning. The discovery began to overheat on my way to work this morning. I havent had a change to pull off and change o2 sensors, but I did scan them and both of the drivers side o2 sensors were throwing codes and were clearly reading different than the other side. Considering this and the fact that it has been drinking just a bit of coolant I am wondering if its a blown head gasket?
If blown,
what rebuild kit should I buy? And roughly how long did it take you guys to do it?
Thanks
Old Nov 30, 2018 | 12:47 PM
mollusc's Avatar
I recently did head gaskets on my new truck, along with timing chain, water pump, oil pump, coils, wires, and plugs, inspecting the rod bearings, and making various tweaks to the evap and emissions systems. Working on a few evenings and some weekends it took about two months.
This is the second one I have done; the first time (on my old truck) I used the stretch bolts and on this one I used the ARP studs. I definitely recommend the studs. Much easier to manage and bring to the correct torque. The Victor Reinz kit also seems to be much better quality than whatever cheap one I used the first time.
Old Nov 30, 2018 | 06:39 PM
Extinct's Avatar
If blown,
Thanks
Yep, you got a blown hg. Buy the bolts and hg from advance - they will give you a 25% off coupon. I have done half a dozen - now takes me 4 hours to get it apart with power tools, 12 hours going back (I take my time). Studs are good but not worth the money IMHO. I have never had a modern HG blow (ie non-oem).
BTW, currently have a set of used, OEM, non-blown hg we could do some evaluation/reverse engineering/failure analysis on if anyone is interested.
discoboy
Aug 13, 2022 08:32 PM
Gromeo
Apr 12, 2013 11:52 AM
khuds308
Jan 27, 2011 06:59 PM
jacklantern
Jan 19, 2009 07:37 PM
StevenDiscoII
Feb 20, 2008 03:08 PM
