Strange noise
Old Nov 19, 2007 | 12:04 PM
greenhulk1980's Avatar
Default Strange noise
Whenever I turn sharply or stop and am turning I hear a loud squeakingor squealing sound almost like brakes but I do not have to be pressing the brakes when this happens. Any tips? I just had every single fluid in the truck replaced about a month ago and it is a 2003 discovery. Any thoughts? It did squeak whenI took it in though. Thanks.
Old Nov 19, 2007 | 01:13 PM
S4poor's Avatar
Default RE: Strange noise
Seeing you had the fluids checked, did they check the belt?
Old Nov 19, 2007 | 05:17 PM
How many miles on your truck?
Could be the brakes dragging or worse yet your front drive shaft u-joints failing. Check and see if you have grease fitting on all 3 of your front drive shafts u-joints?
Old Nov 19, 2007 | 07:34 PM
How do I check for grease fitting on the u-joints what should that look like? and I have 73,000mi on the beast. also what does it mean to have brakes dragging? thanks for the help
Old Nov 20, 2007 | 09:44 AM
If it is an 03, and you have never replaced those 2 u-joints, I would suggest you have a shop look at it and replace the joints.
By the way, u_joints must be lubed every 12,000 miles.
Old Nov 20, 2007 | 10:04 AM
S4poor's Avatar
ORIGINAL: Disco Mike
Did any year come with the U-Joints w/ the grease fitting Mike?
Old Nov 20, 2007 | 12:26 PM
No,
But I have been told that Rover is now selling a replacement shaft for the 03's and 04's that do in fact have grease fitting, just a few years late.
Old Nov 20, 2007 | 01:30 PM
Not to sound like a dummy but if I were looking under my truck where exactly are the U Joints? and what do you think it would run to replace them? Thanks for all the help.
Old Nov 20, 2007 | 01:49 PM
S4poor's Avatar
ORIGINAL: greenhulk1980
Crawl under your drivers door, look up at the 3" round "pipe" that goes from the TC to the front of the vehicle. That is the drive shaft. On both end you'll see joints. U joints to be exact, the look like CV joints.
See the pictures, I circled the u joints in the 2nd pic'.
[IMG]local://upfiles/7363/1E286158848844A3ADFEED71B3F6EF19.jpg[/IMG]
[IMG]local://upfiles/7363/2C184B6C94F14067B68B0984A2B40734.jpg[/IMG]
adowgiert
Jul 1, 2023 12:06 AM
PaulH
Freelander
Aug 31, 2007 04:43 AM
jodilynne516
Apr 9, 2007 02:52 PM
Ali McAuley
Nov 20, 2006 11:15 AM
Durfee
May 25, 2006 02:21 PM
