Stripped/Broken Lugnut
Old Aug 19, 2019 | 02:48 PM
CollieRover's Avatar
Default Stripped/Broken Lugnut
I’m taking off a rear wheel and have had my first bad lugnut. The cover has stripped.
what is my best course of action? Any good methods?
Old Aug 19, 2019 | 03:08 PM
I was able to pound in a 28 and get it off. Luckily I have some extra lugnut with me.
Old Aug 19, 2019 | 06:01 PM
I used to keep a couple cheap sockets around just for that purpose
Old Aug 20, 2019 | 12:09 PM
Jason Feuerstein's Avatar
What I ended up doing when my cover just started spinning was drill a hole in the cover and peel it off with a screwdriver. The steel nut underneath you can put the stock tire iron on.
Old Aug 20, 2019 | 12:29 PM
mollusc's Avatar
yep. i had to tear the stainless covers off so many of those nuts that i ended up dumping the whole set and replacing them with the solid lugs that look almost the same as the capped ones.
Old Aug 20, 2019 | 09:07 PM
Banzai Jimmy's Avatar
Nice. I carry a 12-point 28mm socket with me to the junk yards just for this purpose. Someone tried poking a hole to remove the cover (failed), and rounded the corners on the first third of the lug nut (fail). The ol' 28mm socket got 'em off.
Old Aug 20, 2019 | 11:35 PM
User's Avatar
Take a flat head screw driver and put the edge on one of the sides of the lug, hammer it in and start peeling off the cover. Take some pliers and rip the rest off.
Old Aug 21, 2019 | 04:09 PM
shanechevelle's Avatar
Use a lug wrench, not an impact or air tool.
Extinct
Dec 17, 2017 12:04 AM
nicobaca
Jul 13, 2017 12:16 PM
caymandrew
Jul 1, 2013 11:35 AM
RYAN3326
Jan 11, 2013 09:09 AM
LambChop
Dec 26, 2008 09:41 PM
