Stubborn CEL, Code 1178
Old Jun 14, 2009 | 02:43 PM
Then use water.
Old Jun 14, 2009 | 03:10 PM
kenk's Avatar
I think i might for the fun of it, but i can't think of anything leaking other than the manifold gasket,being I've eliminated all other leak sources. When it all began, my PCV hoses were absolute toast, and I was hoping that was it, but not with my luck...
Old Jun 9, 2011 | 10:09 PM
zracin's Avatar
i have the same code. I ran an automotive smoke machine through the PCV valve tap and found there is a very very very tiny leak on the back side of the intake manifold. I have a liquid gasket, is there any product made to block this leak, maybe by rubbing liquid gasket around the leaky area? or any type of silicone? Im just trying to fix it temporarily till I have time to do a gasket.
Old Jun 10, 2011 | 07:29 AM
kenk's Avatar
I don't think you would have room to get any sort of temp fix on it without removing the intake.
For the fun of it, check the bolts holding the intake manifold on. When I did my intake gasket, some of the bolts could be removed with just fingers. I'm sure that was my problem.
Old Jun 10, 2011 | 08:45 AM
DarylJ's Avatar
On the back of what intake manifold? Upper or lower? Are you talking about a vacuum leak between the upper and lower intake, or an oil leak from the valley pan gasket?
gbob
Jun 14, 2013 02:52 PM
alanroberts50
Nov 4, 2012 06:00 AM
JumPeR04
Feb 21, 2012 10:17 PM
calebbo
Dec 12, 2011 09:40 PM
kenk
May 29, 2009 08:57 PM
