Stuck in Northern Canada and need help trouble shooting!
Old Jan 24, 2013 | 08:02 AM
  #101
If you are still working in a noisy environment, you could hold a stick to the tank and listen through it to hear pump noise. When key is turned to position 2 the pump would run for like 2 seconds.
Old Jan 24, 2013 | 08:56 AM
  #102
vonrock's Avatar
I jumped the fuel relay (87 and 30). It started for about 2 seconds and stopped. So I think that means that I'm getting pressure and enough gas gets through the filtering mechanism to provide a start, but not enough to supply it running.
Old Jan 24, 2013 | 10:02 AM
  #103
vonrock's Avatar
I will access the fuel schrader valve. Jump the fuel pump and see what happens! I'm surrounded by running diesel engines at the moment. Hope some of these guys go to work so I can hear the fuel pump.
I might just go ahead and order the fuel pump and get it on it's way up here. Time is my issue. I'm running out of time. If I order it today, I'll get it by Monday, assuming no highways close in the mean time. We are currently under a heavy snowfall warning and the main highway might close again.
And just to be sure, again, there is no inline fuel filter? All the filtering takes place right at the pump. That makes sense to me, I just want to be sure. The shop manual mentions one, but I think that is the diesel.
Old Jan 24, 2013 | 10:53 AM
  #104
vonrock's Avatar
Inertia switch. How do I bypass it? It is old. Has old wires. Doesn't click when I push down on it. Can I just connect the two wires somewhere along the line?
Old Jan 24, 2013 | 12:10 PM
  #105
SuperSport's Avatar
IF this image is the right one, then no, only on the Pump.
Attached Thumbnails Stuck in Northern Canada and need help trouble shooting!-fuel-system.jpg
Old Jan 24, 2013 | 12:55 PM
  #106
vonrock's Avatar
Ok. Finally found the schrader valve for the fuel line! OMG.
I tiny bit of gas dribbles out. Then virtually none while cranking. Let her sit for a while turn the key to position 2 a couple of times, and there is a small bit of pressure built up again. Then none. None while cranking.
I've put more gas into the tank, it's about 2/3 full and nearly an ounce of methyl hydrate.
I'm going to pull the trigger and get a fuel pump sent up. I want to keep trying to pump gas small bits of gas through the line so the methyl hydrate can work and clean up any ice that might be in the line.
While filling the tank up from a jerry can this morning I noticed how easily snow can slide off the window and roof above the gas tank while filling and drop right into the gas filler part of the tank. I must make sure I'm careful with this in the future.
Thanks everyone. I'll keep you updated.
Old Jan 24, 2013 | 01:10 PM
  #107
vonrock's Avatar
I tapped on the switch a few times to trigger it. It did reset when pushing down on the button.
Old Jan 24, 2013 | 03:13 PM
  #108
94svt50's Avatar
I think if you pull your pump you will find the pickup filter clogged. I know Im saying this over and over but, to me it seems highly likely. I have experienced this numerous times on various farm equipment.
Old Jan 24, 2013 | 03:35 PM
  #109
SuperSport's Avatar
Or, Ice in the fuel lines. Could always heat them with a torch... Just KIDDING!
Old Jan 24, 2013 | 04:47 PM
  #110
94svt50's Avatar
They would thaw in a hurry!
How cold is it there?
