stuck on side of road and need help asap!!!!!!!!
Old Aug 15, 2010 | 11:15 AM
Dino76's Avatar
Default stuck on side of road and need help asap!!!!!!!!
Heading home from a trip and my gear indicator switched from D to a flashing symbol. Pulled over and it wont come out of park. Brake lights work so its not the break sensor. Also checked fuse and it was fine. I beloved the problem is the park neutral switch. If so is there anyway to bypass? Please call with suggestions 704-267-4470
Old Aug 15, 2010 | 05:12 PM
Dino76's Avatar
Default update
I made it home but don't know how. I check all fuses, and opened the the shifter cover and there was some trash in the area. Once removed the blinking gear indicator remained. I was able to get it into gear and make it home. Really don't know how. After a couple miles the gear indicator cleared. Any ideas? Maybe a loose wire?
Old Aug 15, 2010 | 05:34 PM
handsome rob's Avatar
I do not know, see if you can replicate the issue and get back to us. At least you made it home though.
Old Aug 15, 2010 | 06:05 PM
Very well could have been the trash in the gear shift, could also be a weak battery.
Old Aug 16, 2010 | 12:05 AM
bosshogt's Avatar
Dido on the weak battery. I have read on previous posts that the M & S green lights flash on the instrument cluster.
Old Aug 16, 2010 | 12:18 AM
snowdude's Avatar
The M&S lights flash because the transmission ecu is the first to lose power when voltage is low.
Old Aug 16, 2010 | 07:42 PM
Dino76's Avatar
I have a new battery but I have noticed that when I press the brakes the interior lights are very dim. Also the horn is extremely weak. Think the alternator might be going out?
ImQuattro
May 1, 2014 08:36 PM
LR03NJ
Aug 6, 2013 12:26 AM
jhill15
Mar 30, 2013 02:52 PM
aarongregor
Apr 25, 2012 04:59 PM
Brokenrover
Dec 14, 2007 08:27 AM
