Stuck sunroof
Old Aug 15, 2008 | 09:42 AM
AK Rover's Avatar
Default Stuck sunroof
I went to open my front sunroof yesterday to find out that it would pop up but only one side would move when it tried to slide. The 2 sunroofs are one of my favorite features of the truck and would hate to lose their use. I tried spraying white lithium grease on the track but could not get down in the track sufficient enough to do any good. I'm think of trying some penetrating oil hoping it will work it's way down in the track and break loose whatever is keeping it from moving. Any ideas if this will work or maybe better ideas to try?
Thanks
Tom
Old Aug 15, 2008 | 01:29 PM
Default RE: Stuck sunroof
You have not been keeping the tracl and lift clean and lubricated.
Most likely you will need to replace this one roof system.
Old Aug 15, 2008 | 04:58 PM
AK Rover's Avatar
What would I need to replace? I was looking at AB and found a sunroof guide assembly set. Is that what I need or is there something else?
Old Aug 15, 2008 | 06:44 PM
Ranchrover's Avatar
If no parts are broken (cables, etc.), you may be able to remove the glass & clean the tracks. Then see if it works without the added load of the glass. That worked on my daughter's Alero. Put it all back together & say a Hail Mary.
ImQuattro
May 1, 2014 08:36 PM
dominiquetx
Mar 9, 2012 11:53 PM
BigRed98
Jun 21, 2010 12:30 AM
tsampler
Feb 19, 2009 05:49 PM
XtremePowerSports
Sep 22, 2007 08:06 AM
