Stumbeling Idle
Old Dec 12, 2007 | 07:09 PM
Tastang's Avatar
Default Stumbeling Idle
I have tuned up, replaced and cleaned everything I can think of but even after having my heads redone I still have a little stumble in the idle. It's not enough to throw a code or even feel like a dead miss but it is enough to get on my nerves. Is this just the way this motor is supposed to idle?
Old Dec 12, 2007 | 08:17 PM
okdiscoguy's Avatar
Default RE: Stumbeling Idle
Fuel temp sensor? It is also possible you have a bent valve. Happened to a friend of mine with a 2000. They did his head gaskets and missed the valves..
Old Dec 13, 2007 | 08:38 AM
Did you clean your throttle body and Idle control unit? Have you checked all hoses for a leak or blockage, what spark plugs are you using at what gap, how about plug wires, what brand?
Old Dec 13, 2007 | 06:43 PM
Tastang's Avatar
I'm pretty sure the valves are good...I had them check the heads good because the head gaskets did not look blown so I thought I may have had a head issue. I am running Bosch 4's with magnecors. It did this before I put the wires and plugs on. I did clean the T-body and IAC plus seafoam. There was a K&N filter in when I bought the truck but I quickly replaced it with a reg filter so I'm not sure if maybe the MAF sensor may be going bad or maybe the IAC? I did find one black hard plastic line on the firewall right beside the brake booster that looks like it could be broke or may be a vent for something, it doesn't feel like its pullin any vacuum.
The truck runs great at any rpm's and pulls great on any incline, its just the little shake in the idle driving me nuts.
Old Dec 13, 2007 | 07:02 PM
browndogq's Avatar
Have you done a compression test? I would start with the basic troubleshooting(compression,spark,fuel).That being said I have seen a weak coil do this. Good luck
wick_60010
Nov 22, 2017 04:25 AM
KGN96discoSE7
Sep 23, 2017 07:23 AM
westernsun
May 27, 2006 04:24 PM
pinoymoomoo
Sep 24, 2005 01:39 PM
slamwhit
Jun 17, 2005 05:11 PM
