Stupid Question: Rear washer pump
Old Jan 28, 2008 | 07:38 AM
R_Lefebvre's Avatar
Default Stupid Question: Rear washer pump
Just got this truck, but don't have an owners manual so I'm a little lost...
I tried using the rear washer, but no fluid comes out. I held it for a reasonably significant amount of time just in case it needs to be primed or something. Nothing.
I know the bottle for the front fluid is full... is there a seperate rear bottle? Or does it draw from the same bottle as the front? If so, I guess that means I have a problem.
Is there a seperate fuse for the rear pump? If not, I guess the pump is pooched?
Old Jan 28, 2008 | 08:23 AM
Default RE: Stupid Question: Rear washer pump
Sounds like either the rear pump motor is bad, the rear washer jet is plugged, or a line between the fronty bottle and the rear washer is plugged.
Crawl under the l/front corner of the truck, under the headlight area and you will see one bottle with all 3 pumps.
greenharoguy
Feb 19, 2013 08:52 PM
ih102
May 21, 2012 01:51 PM
lrjon
Mar 14, 2012 10:00 PM
humroot
Mar 12, 2010 06:31 PM
krazzz
Jan 15, 2010 07:17 AM
