Subwoofer Mounting Depth
Old Jul 30, 2017 | 04:33 PM
Sean Winter's Avatar
Default Subwoofer Mounting Depth
Have a Disco 2, 2002. What's the best depth for an easy replacement of the cargo door subwoofers?
- Nice subs are about 3.35
- Saw one guy install a 3.00 depth(had to trim enclosure)
- Guessing that 2.5 depth is closest to factory? They are pretty average sound.
Thanks for the help.
S
Old Jul 30, 2017 | 05:08 PM
Alex_M's Avatar
I wouldn't put aftermarket subs in the factory housing. Anything that pushes more air will very likely rattle the door quite a bit.
That said, I think there is a cut out in the door itself that will allow you quite a bit of depth. I'm not positive though, so don't hold me to it.
Old Jul 30, 2017 | 05:42 PM
OffroadFrance's Avatar
Don't forget the air baffle or you'll blow the speaker cone to bits.
I reckon the LR D2 s/w is circa 3" deep.
Old Jul 31, 2017 | 10:40 AM
Is it possible to put two 6.5 speakers in the cargo holder instead of subs? Basically bring more real sound into the car? Or are they wired for sub through the amp?
S
Old Jul 31, 2017 | 10:44 AM
mollusc's Avatar
They're wired to the sub outputs from the amp. I put two regular-range speakers in mine since the cones on my subs were destroyed. I don't do huge volumes so they work okay.
Old Jul 31, 2017 | 10:48 AM
So you just added regular speakers? Do they have a low level sound? Or am I off on this.
Old Jul 31, 2017 | 11:06 AM
mollusc's Avatar
Yes, they have low level sound. They are full-range speakers.
The crossover in the system amplifier directs only the sub-level frequencies to those speakers, so only the bass comes out of them. Since they're not specifically designed as subwoofers the sound they are not as efficient or as clear as you'd get from true subs, but it works well enough for my listening.
Old Jul 31, 2017 | 11:07 AM
JUKE179r's Avatar
I like bass so this weekend I added the 6.5" Pyle PLG64X 4ohm 300 Watt Gear-X series speakers.
fyi... I've read that the stock rear door speakers are 2 ohms so I wired both of my new 4ohm speakers in parallel from the stock amps 1 connection (pos & neg) to equal 2ohms.
Of course these won't thump like a 10" - 18" subwoofer but for $10 apiece they added some umpf to Myrtle's sound system.
Old Jul 31, 2017 | 11:08 AM
Thanks for the idea!
Old Jul 31, 2017 | 11:10 AM
Any cutting, or did they fit well?
Thanks
S
