Subwoofer Mounting Depth
Old Jul 31, 2017 | 11:16 AM
mollusc's Avatar
Originally Posted by JUKE179r
I like bass so this weekend I added the 6.5" Pyle PLG64X 4ohm 300 Watt Gear-X series speakers.
fyi... I've read that the stock rear door speakers are 2 ohms so I wired both of my new 4ohm speakers in parallel from the stock amps 1 connection (pos & neg) to equal 2ohms.
Of course these won't thump like a 10" - 18" subwoofer but for $10 apiece they added some umpf to Myrtle's sound system.
Sub channels are usually mono rather than single, but if there are two discrete channels going back there then you've just shorted them across each other.
Old Jul 31, 2017 | 11:37 AM
JUKE179r's Avatar
I used only one channel from the stock 2ohm amp to parallel wire the 2 mono rear speakers (subs). not so much shorted but dropped the resistance to 2 ohms at 1 channel instead of 4 ohms at 2 channels.
Old Jul 31, 2017 | 11:47 AM
Luckyjayb's Avatar
I've been wondering the depth BC I want to put Memphis car audio back there but for the sound quality. I put two sony xplod's and not a big fan of it
Old Jul 31, 2017 | 11:54 AM
Sean Winter's Avatar
I think these are close to the previous Pyles mentioned. Little more watts. 2.9 depth.
Pyle PLPW6D
Old Jul 31, 2017 | 02:10 PM
JUKE179r's Avatar
3" is about right for the depth. I compared the stock old speakers to my new Pyle PLG64 and they were the same height but the magnet on the Pyle is bigger/wider. I had to drill and roll back the panel a tad bit on inside top and bottom to make space for the speaker so it wouldn't rub on the magnet. BTW the Pyle's have a rubber ring around the magnet.
There are other 6.5" speakers that are sold as low profile/shallow speakers but they are more money... $95/pair and up.
Old Jul 31, 2017 | 02:37 PM
JUKE179r's Avatar
Those Memphis PRX6D2 6.5" look nice but the magnet looks huge. You will definitely have to mod the panel to fit that.
Old Jul 31, 2017 | 03:47 PM
Luckyjayb's Avatar
yea but damn they sound great. That's all I've ever used in my vehicles and they are worth every penny
Old Aug 1, 2017 | 08:18 AM
I picked up these on Amz - Pyle PLPW6D. Will take photos and measurements while installing.
S
Old Aug 3, 2017 | 02:13 AM
Rlozano's Avatar
I just installed the Pyramid WX65X from amazon today. They sound and fit great. Was able to use original mounting hardware and screw spots. Had to bang for a little clearance on the right side to give a little more access for the larger magnet. Left side was fine. Needed roughly about a 1/4". Cut the leads of the original speakers, crimped some connectors to them and worked perfect. Was able to use the stock connector mounted to the enclosure just like stock. Couldn't be any happier.
Oh and they are 3.4" deep and had no trouble.
Old Aug 8, 2017 | 08:53 AM
I've mentioned this in the audio section, but I bent the small female connector and attached both original wires to the PLPW6D. These work without any alterations. Sound great.
They have fat magnets. Is there anyway to squeeze them in the cargo hole? I dont want to cut the hole, maybe bend the metal? Only needs about .5in on the right speaker.
Help.
S
